My first CB as a young teen in like 1999 – 2000 was a 1977 Royce 1-621 base. Used it for like 5 years and it worked well, someone also modified it so it had 40 channels below one and had like 15 channels above 40. The power supply eventually blew a transistor which I swapped out with something I had on hand, but I already had other radios so wasn’t really using the radio by that time.
I still have this radio somewhere in the basement, have not used it since around 2005 or so, and haven’t hooked it up in at least 10 to 15 years now. I will say I could not figure out why, but the lower channels eventually stopped working, the switch and wiring was good, they had one leg of the switch grounded, the other went to a pin on the PLL chip if I recall. Also, someone swapped the knobs with Sears Roadtalker knobs, the one with the black rubber for the grip; useless tidbit I remember.
Perhaps not a great radio, but I miss those days of me and my cousin late at night chatting on that CB, I had a Turner Plus Three desk MIC which worked okay, and then got a Cobra CA75 hand power MIC which did not seem to sound very good, everyone said to get a D104 hand MIC and I did not listen
. The receive audio sounded decent enough, transmit was nothing special but was able to chat with it. At any rate, that radio gave some fun times, worked okay for local chit chat and the occasional skip.
Years later had the larger 1-625 base, but eventually sold it when getting rid of stuff I was never going to use, and think I got another 621 base at a hamfest really cheap which I also eventually sold. I still may have some old Royce mobiles, but were probably parts radios.
edit: you may notice the numbers in my name, those were my DX numbers I got from that Royce radio when I was learning about skip / DX.
