Replaced all the caps on the input side. Only thing I didn’t replace is the combiner. But it seems to test ok.
Hi Jim,I have tested and replaced everything I can think of except transistors. Is it possible some transistors are shorted and preventing drive to reach other transistors? And how can I test them?
Aint transistors fun?Tested and found 3 with a diode fault,one with leg broken off. I likely broke it removing it.3 had HFE of 2. 1 was a 3 HFE. The other 2 tested 16&17 HFE. Think the diode shorts caused the 0 output? Now got to figure out what I want to replace them with.
You can buy dc supplies on amazon for $19 each that will give you a solid 25a regulated. Buy a bunch, put them in parallel. Problem solved.View attachment 71510The new set of matched HGs from ICA seems to have fixed the issue. I have only put 10 watts in and get 150 out. I still nervous about driving it with the 150 in. The built in unregulated power supply supplies about 21 vdc tapped on the 115v source. I really would like your opinion on using the variable ac unit between the wall outlet and the amp plug. Reducing that voltage should drop that 21 vdc down. What VDC range would you recommend running the HGs at? Again I really thank everyone who helped me with this repair.
So what did you wind up doing?I wanted to come to the thread and Thank everyone who helped. Running really well with minimal heat. Again thank you all. 73’s.
Oh...ok. i thought you were going to fiddle with the power supply side.Replaced all the Pills with matched HG’s. Verified all the transistor diode side resistors was good and in tolerance. Replaced all the combiner resistors with original 2 watt 100 ohm resistors. As well as the transistor feed back resistors. No heat except the normal transistor heat. Thanks again for all the help.
