BLJ 500
88_bandit
24
3
33
Yes I am rebuilding a BLJ 500 Tube amplifier and was wondering what value of bleeder resistor I should use ohm and wattage. Thanks
  • @ Geoexplorer69:
  • @ Geoexplorer69:
