I'm pretty sure that I'd seen the 10-turn clarifier on CBTricks in their "Secret CB Files". It might takes some digging to find, but...
This isn't for a 10-turn clarifier; but just for extra slide on the 148.
I think it requires a 'super diode' to make the the 10-turn work correctly.
COBRA 148 GTL SLIDE
1. --- Remove R-44, R-175 & D-52.
2. --- Install jumper where you removed R-175.
3. --- Move orange wire on Clarifier to Pin 1 of IC-4
4. --- Jump R-174 or clarifier WILL NOT center up.
NOTE : L-23 (AM), L-59 (USB), L-22 (LSB), will have to be readjusted for center slot on Clarifier control - some units slide more than others.
NOTE ALSO: if you change D-35 to a ECG-612, the stock clarifier will be sensitive and hard to control so, you will have to change VR-502 to a 10 turn pot.
After doing this you MUST re-tune L-23, L-59 and L-22. See my tune-up section {above} on the Cobra 148 GTL.
It would be a good idea to let the radio settle out for a few days in the ON position then re-tune it again.
"WANT MORE SLIDE?"
"1. Remove D51 and put in a jumper."
"2. Install a "super-diode" in place of the stock varactor D35."
"3. Or, add a 4.7uh to 10uh choke to the banded-end of the stock varactor."
SLIDE AND ALIGNMENT FOR THE 148GTL MY WAY
