10 turn pot for Cobra 148GTL Clarifier ?
Switch Kit
Well-Known Member
Apr 6, 2005
3,614
169
63
Was hoping someone could steer me in the right direction on finding a 10 turn pot that would work on a old school 148 GTL's clarifier , one that might fit one way or the other. Much thanks ! Switch Kit
20KB 20k linear taper
To get this to fit in a 148GTL, you will need to make some mounting/fitting modifications.
Another option is to use a Cobra 2000 clarifier. It will give you a Course & Fine and will physically fit without modifications. You will need to use "Keyed" knobs but they aren't that hard to find. 20KB + 1KB
$7.95
Cobra Inner knob
Cobra Outer knob
Shadetree has the right idea. A multiturn pot is not that useful without a turns-count dial on it. The position of the knob alone tells you little about where a 10-turn control is set.
The count dials tend to cost more than the control, and present a mechanical issue getting them mounted.
Not the best solution IMHO.
Reactions: Switch Kit
i remember years ago ops putting 10 turn on ssb clarifiers but also putting a diode in radio somewhere to make it widebanded,,,,
$7.95
Cobra Inner knob
Cobra Outer knob
I like this idea. Might have to look into this for other grant xl I have.
  • @ kopcicle:
    535A has left the room.
  • @ AmericanEagle575:
