My never ending quest for the best antenna system I can have has led me to this antenna but, With my limited knowledge, I would like to know why If at 27.205 mhz the antenna is happiest at 103.216 inches does everyone just throw a six inch spring or riser under them? I understand this helps with SWR but would one not be better off with an equal or close to it split? Say a three inch riser for an acceptable SWR and a far more resonant antenna. It has been written that "You really do not need to "tune " a 102" whip, you need to match the feed point impedance." I have been to and read K0BG`s Web site many times over and sadly I understand about 3/5 of the information there. Should I try for a happy medium or just go with the flow and add a six inch riser?
