B
BOOTY MONSTER
Guest
so just because..................i tried a SS 102 on the roof of my montero and it wouldnt go below 2.5 for the swr . i did swap out my older coax for a new section of belden 9913F7 14 foot 8 1/2 inches long per this formula . "468/27.195=17.21 ft X .85 = 14.63 feet or 14 feet 7.5 inches"
the 10k tuned fine just like it did b4 but the 102 was really high . i know a 6 inch spring or spacer is needed to be a true 108 1/4 wave whip , but i was expecting a acceptable swr reading without it . we double and tripple tested the coax for proper assembly and i have contiunity between my roof and vehicle frame and the negative on the battery . i also resanded the area around the mounting hole to be sure i had shiny clean metal underneath for optimum grounding . the mounting stud was taken apart and reassembled with no visual dammage and very careful reinstallation . its a lug mount stud , CATALOG Main Page (Frame Setup) .
i was really suprised . i expected the 102 to kinda be plug and play . i have absolutely no problem with the 10k . it works just fine , i just wanted to play with something different and the 102 was a "good excuse" (cough cough) to upgrade the coax too . what would cause this ? ive got good ground , good coax and a good mounting stud .
oh yea , we used 3 different meters he had a electronic MFJ and a 3 window dosy and i had my astatic 700 . the 10k would barely move the needels on the dosy and 700 but the MFJ showed 1.3 to 1.4 from channels 1 though 40 . on the 102 both needles were in the red and the MFJ was almost 3 to over 3 from channel 1 through 40 .
sooooooooooooooooooooooooooooo..............whatsgoingon??????
