16 years and I got one!
mechanic
Mar 4, 2009
596
127
53
North coast of the USA.... Da UP!
A lot of water went under the bridge but the wait has come to an end.... Three days ago I plunked down 125 dollars and now I am the proud owner of an Emperor TS5010! :D
Not that it is perfect but it looks nice, few scratches, a little dusty. But the biggest fault was sporadic drifting on SSB, not much mind you but just enough to play "chase you, chase me" with the clarifier... :headbang
I thought it might be the voltage circuits so I opened her up and checked from the power cord forward... Something did not look right... :glare:
Brown stuff near the base of the two main filter caps, under magnification there also was some green crud, corrosion! :unsure:
I remember reading somewhere on the NET about leaking filter caps and the damage that can occur. So I went to Rat Shack for some new ones. Only found 1000 µf @ 35 volts, So I bought two for $1.59 each.
Desoldered the old ones and cleaned the board, powered her up and much better.... or so I thought... :cursing:
Tapping on the side of the rig I could make the fault come and go and with the top cover off I put some pressure on the main board near the 8 volt regulator, tapping now would not make the fault happen! :wink:
Turning the rig over I remover the speaker cover and the daughter board, magnifying the area near the legs of the 8 volt regulator I could see a bad, intermittent joint on the input leg! :w00t:
Checking the whole area over I re-soldered all three legs of the regulator and no more "wobbly" SSB! :biggrin:
Caps can age and leak or short and solder joints can part or crack, (mechanical motion from being mobile?) :blink:
The radio now works great! Now I know it is a step (half a step) down from the famous HR2510 but I always wanted one and now I do.....
Sorry for the long praddle on this but I wanted to pass on my findings of some small but big problems that can happen to a rig, especially a mobile.
73 mechanic
P.S. This tail is not finished.... The radio has a brother!
Till next time!
sweet......
Nothing sweeter than finding that radio you always wanted.:biggrin:
Then discovering it has this 'teeny tinny' little problem.:sad:
Then making it all better.:thumbup:
Nice trouble-shooting!
Way to go!
Congrats on getting (and successfully troubleshooting) the rig. I wanted one of them in the worst way years ago. Enjoy!
73 & Good DX,
Sparky 2CO3026
