Just made my first 2 contacts on 160m. I had never been able to tune 160 before with my Windom but I recently moved it and decided to give it a try tonight and it worked !
I'm not having any RF issues. I do have a 1:1 Ugly Balun installed that eliminated stray RF. One thing I do want to do that gives me a problem is make the wire more conducive for 160m by making it longer. It is not designed for 160m even though after moving the wire from 7ft off the ground to around 20ft and away from objects I was able to tune with the tuner. 160m was the only band I had a problem trying to tune. The other bands I use the wire for tune up great. I am thinking of making a 1/2 wave dipole for 160m and use the Windom for 75m as I was told the 160 dipole will not tune 75 but is great for the other bands. How is your mystery antenna working for you ? Have you used the Windom ?
Good deal on the contact and antenna David ! I just totally changed my antenna. LOL ! I took down the Windom and converted to an 80m dipole. I just made contact with a Georgia station on 40m and a nice Florida contact on 20m. I had a strong 5/8 signal into Florida. I think I'll play around with this dipole and see how it works.
