I have been running a 2 antenna beam setup with the front hot and rear grounded or capped for years with very low reflect. I've always run into problems with reflect and blowing boxes when I run 2 coil antennas (davemade&pony) coils between 6-7 ft. apart. I do fine when I keep the volts down, But when I volt anywhere between 15-21 volts I usually blow within minutes to a hour. I can have less than 1% reflect on the coils and still have this problem. Does anyone know how I can beat this? I forgot to mention that when I run the two 1/4 wave war stick beam setup (front hot) everything works fine and I can run up to 21.5 volts on my davemade driver and main box. I hope that someone can help me because it is getting to cold for me to keep climbing my old self on top of my van when I want to drop down the worldwide Maul. I would rather leave my ride around coils on.
Thanks in advance,
Hitman 043
Thanks in advance,
Hitman 043
