ok this might be or sound confusing but lets give it a try. scenario#1
this is on 2 antenna set up. tune 1st antenna to lowest swr then move it to the back
then 2nd antenna in front again tune for lowest swr.endedd with 1.1 swr using just a barefoot radio.
now connect the amp with amp on damm 52 watts of reflect on bird meter of course
re check with a swr meter yeap high 1.8 swr.ok now we start over again rear antenna in the front tune for lowest swr/reflect move it to the back put front one on tune for lowest reflect/swr. now here is were i'm confused ended with a 1.1 swr with 3 watts of reflect.
also i notice on scenario#1 antenna was a certain lenght=stinger height.
scenario#2 ended with stinger a bit higher than the 1st test.
by the way i recheck and tested the swr with 2 different radios same results.
now i need to figuire out what change. but still ended with same results.??
