hi all,
just replaced the FETs in my counter module, as it was getting erratic.
switching to 11.xxxx for a second and then switching back.
i replaced all the electrolytics in it about 2-3 months ago, and it worked the same afterwards.
i am now getting the dreaded 92.2000 readout in AM, and 0.0000 on SSB.
replaced D528 with NTE136A.
i tried replacing the two transistors and the SCR mounted on the rear panel with NTE replacements. no change.
put stock ones back in. old FETs could not be salvaged.
old ones too haggered to go back into chassis.
i also found one tantalum cap (.47uF) on the board that the schematic says is supposed to be an electrolytic, so i replaced it with one.
when putting my RF voltmeter (dont own a scope) on TP504 (IC512 pin 5), i get no reading and adjusting L501 does nothing.
similar result when on TP502 and adjusting L502.
no reading on RF voltmeter.
so, no RF output?
did i somehow blow IC512? i was very cautious about static electricity.
the stock FETs in my counter were:2SK192a
i replaced them with NTE312.
should i have used the NTE133?
yes, i know about NTE parts being relabeled parts, but assumed they would work in this app.
any help is appreciated.
loosecannon
so, no RF output?
loosecannon
