28.420usb
n0zna
Digital master
Nov 3, 2008
1,255
167
Missouri south of St Louis
Since the sfi is up to 121 i brought my old siltronix 1011d out of retirement.I been on 28.420usb the last 3 days and had a blast.I even went to 29200am and made a few contacts,hope to hear you out there.I been on from 1600z till 0400z.I am in bad health so not on all the time,need to lay down for a while.Im on for a 1/2 hour then lay down for 1 hour...73s de n0zna/John em48sd
...i brought my old siltronix 1011d out of retirement...
a 1011d? ,... a 1011 DRIFTER? keep it turned on and warmed up;);)
10 has been good for the last week or so in sw florida.
lots of western states, S. America, some europe, & Australia
Been too busy with work to turn on the radio the past three days...dangit. Keeping my fingers crossed for band openings over the weekend.
10 meters
Yes I have made a handful of contacts on digital modes on 10, gld to see it open once again, and forgot about 10 am, will have to give it a try..
DOCTOR/795
10 is open now to africa/ect. 1430z
just worked 9J2GS 28.477, D2AM 28.490 and ZS6AJS 28.501
with 100 watts on fone.
Hi ZNA, I love to work AM on 10 and my 2995DX is an audio monster there. Will look for ya on 29.200. MO. may be a stretch (too short) but we do get Texas fairly regularly so you never can tell. I'm more likely to get the west coast here lately.
Good luck and enjoy!
Maybe when 10m gets a little more reliable we can get a net going. Just a thought.
I 'll try 28.420 tomorrow around 1700Z and then 29.200 AM. Listen for = WD8T
10 and 11 meters has been open pretty much everyday, late morning through sunset for quite a while. Mostly long range, east coast to west coast type stuff.
Been on 28420usb since 1600z...South Am and Central Am...worked ce3/lu1fam and ti5/w4dr and p49y all s9 or 20db...its still open,but cant wait till grayline,it was rocking last night...73s de JW em48sd:thumbup:
10 was hot this past weekend. I decided to participate in the ARRL Int DX Contest on sunday. I was on the air for 3 hours and worked 36 countries. 26 countries on 10 meters..the other 10 on 20m and all with 50 watts. 10 is amazing when its open!
We have a local gang here in Ottawa that monitors 28.420 all day and night. Most are mobile, some are based at home. The mobiles run anything and everything. I also monitor 29.000 - 29.050 AM too.
Last night I worked ZL1BYZ in New Zealand on 28.007, CW, 23:17z. He was working split with a nice pile up. He is a good operator.
Conditions tonight should be good. SFI at 155.
What happened? After a couple of good weeks 10m has crapped out. I was all set to play in the 10-10 Int. Mobile QSO Party last weekend and the band was D-E-A-D. Not even one contact for three hours of mobile ops.
I aam hearing the occasional South American or Caribbean station come and go, but that's about it.
10 meters was hopping a bit earlier today in the tech portion of band....fell out about 30 minutes ago...time is 5:30 centeral
17 meters has been running hard and heavy all day,Europe was booming in till about 1 PM,alot of state side working now
  • @ Geoexplorer69:
  • @ Geoexplorer69:
