29 ltd chrome help
1iwilly
Dec 7, 2008
860
626
103
63
i pick up a 29 ltd chrome nice radio until i look inside who ever work on this radio should have and be ban from owning tools.LOL they remove the TVI slug
for variable power they tap into the vr-4 pot= amc then they remove jp 32 and ran the other wire from the pot to it then they cut the wires from the swr/cal and cut the wires for the talkback pot. i got the radio back to almost stock conditions what i need if anybody here has one of these if they can tell me on the talk back pot where the 3 wires go the black one is still intact but i can find where the other 2 wires go thanks pictures would be even better i know i'masking for alot here but that is the best i can do for now
update on top off everything they took out tr18 even though they cut d-11 ok i made some progress i'm just missing a white wire on the middle leg and a green wire on the outer leg from the front terminals of the talkback/swr/cal also on the rf meter/swr &cal 3 position swith looking at it from the back top terminal left =yel right=brown second row left=yel right=blue 3rd terminal are blank bottom
left=blue right=pink
well thanks to all that read my post i got her fix dum ass forgot i had 6 other 29 on the shelf took a look inside same exact wiring she is back to stock from 2 watts on the bird swings to 8
put all the limiters back in got a radio check clean and loud i adjust the TVI trap as best as i could using an old tv on channel 54 HEHEHEHE.LOL but she is fixed
