2950dx meter swing
123kid
328
36
38
41
When i key 269650 and above on ssb my meter swings to the top but below that the meter swings half way.I get full bars above and only half below 279650.Why is that?Is it a high swr issue because when i connect a external swr meter it says on 269650 my swr is 1.1 and on 274050 my swr is 1.3.
seems ass backwards
Robb is exactly right, The problem or what your seeing is the tuning or efficiency of your antenna where it was or is tuned is where your going to see best performance.
This is why all CB antenna tuning instructions have you tune and check SWR on channel ( 1 ) 26.965.0 and channel ( 40 ) 27.405.0. By setting or tuning antenna on channel 20 will help even out the Standing Wave Racial on the straight 40 CB channels but if you want broadbanding you have to figure out where you are going to talk up and down the band and tune according to thos 2 points.
    6m SUKS today damn...lousy condx...did work FLA but still PB "Pretty Bad" :love: :mad:
    list'n 50.125 USB...working in shop...also 2m FM Simplex freq's 6.52...6.46 ... 6.55 etc..:ROFLMAO::coffee:
    Called you twice Mr. G.......................
    I was look'n your way Evan...was working on some lighting in the garage...you were just "Thr" but w/ fade...you were gone...so did not fire the heater and call :cool:
    Roger that, 6m on the HexBeam is lame.
