Really doesn't sound as if the SSB bias was adjusted successfully. The component values visible in the pics are valid for a MOSFET final and driver, not a bipolars. AM mode is not so finicky about this, but listening to the sideband transmit audio on another radio should reveal an issue. Turn down the mike gain so the wattmeter won't kick above 1 Watt when you talk. If I'm right there will be a "gritty" quality to the audio that goes away bit by bit as the mike gain is increased.
Popping the "mirror" board and connecting a current meter to check SSB collector current with the mike gain at zero should show zero idle current.
And if AM is all you care about, it ain't broke for that mode.
