The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
as long as The Driver is not too much or Not enough you'll be OK But Sometimes There is too much (Capacitance for bigger final) too do there thing So you might Have too Experiment a little if no 1 else has done the work before YOU GOOD LUCK:headbang
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
