Deedle,
Tune your antenna with the linear off. Or out of system. The higher the power the higher the VSWR.
Just the radio and antenna. Get it as low as possible. Then operate. I rarely, if ever use the high setting. Usually low or med. 26 years of running radio with amp and never a problem.
Remember most Low Drive Amps no more than 4w input. Preferably 1w. I blew my 148 driving 6~7w into the Palomar LD 450.
Good counter poise, or GP is crucial. Good connections through out system, and grounding. Bonding will be worth the effort.
Roger that! Thanks for the pointers. Like you pointed out it's no use running at max power since, in my experience, after about 150W there is little difference so max is always on level 2 when the linear is on, and I set it back down to that after making sure SWR was as low as possible at the highest setting. When it gets nicer out I'll be drilling the roof and make sure it's bonded for best performance. My truck has a roof rack so I might make something custom for the antenna on top of there instead of drilling the roof, as an alternative. Also this amp is high drive so I can put about 35W into it to get 300+ out, from 3.5W (stinger off) I get about 75W out on max setting. The 980 SSB stinger takes 3.5W to 35W average. I don't run the linear in normal operation, just when testing.
I take it your truck is not a pick up?
If you decide to drill consider placing a backing plate bottom side of roof. Flex will mess up a roof. 3-4 inches dia. or larger if possible. 1/8" thk. Run a ground wire from plate to frame you can tether bonding wires from this to panels. You gotta pull the head liner any way. Might as well do it right.
And see www.k0bg.com on mobile install. Hougen Rota-Cut.
Alan's site is the mobile install bibleAwesome site, thank you much!
You are thinking rotabroach, not rotacut. The rotacut is a fancy hole saw that can be used in a hand drill.Pretty sure attaching a mag drill just might be a weeeeeeeee bit over kill for sheet metal and 1/8" thk. metal. I read some of that site. Had some good pointers. You have to improvise a lot of things and try others.
