Your killin me smalls!!!I can’t blame ya. Those Ford pickups are rare as hens teeth.
You are correct! I had to buy a TRAM Model 1295 MNO to 3/8"-24 Adapter so as to thread the President Iowa into it. As soon as I installed the 40" antenna, I realized that any taller antenna with a heavy, bottom, mid or top coil would put strain on the third brake light and the cab. I ventured-out (gambled) and purchased the Third Brake Light Antenna Adapter and my personal opinion is this type of mount should not be used for CB antennas.That mount is really for 3/4 nmo antennas. I looked that mount but price to high and would not fit any of my antennas. So I use my 102 whip mounted on tool box works just fine. I will try the president on the roof BUT man it is heavy....put in a Wilson roof mount. so we will see...
Sorry, I do not have any pictures of the install but I could send you a photo to your email address if you want.Do you have any pictures of the install?
I do not have pictures of the install, but you can see a few photos online @ Bulletproof Diesel Third Brake Light Antenna Adapter. I ventured-out, taken the risk to buy and install this mount, but it was a bad (and expensive) mistake. I removed the President Iowa antenna and placed the plastic cover on the NMO threads. The snow has arrived here and I think when heavy snow and ice get blown off the roof and strike against the bottom coil, the mount may flex and crack the brake light lens and distort the cab.Do you have any pictures of the install?
I haven't given-up yet. I ordered a 49" Browning BR-140-B CB radio antenna with a bottom coil and with NMO threads. I'll give it a try and attach it to the third brake light antenna adapter.That mount is really for 3/4 nmo antennas. I looked that mount but price to high and would not fit any of my antennas. So I use my 102 whip mounted on tool box works just fine. I will try the president on the roof BUT man it is heavy....put in a Wilson roof mount. so we will see...
30 NOV @ 1540 UpdateDo you have any pictures of the install?
I purchased and installed a Browning BR-140-B NMO Bottom Coil CB antenna and installed it on the Brake Light Adapter Mount and it has been working pretty good within a five to ten mile radius which is all I need.That mount is really for 3/4 nmo antennas. I looked that mount but price to high and would not fit any of my antennas. So I use my 102 whip mounted on tool box works just fine. I will try the president on the roof BUT man it is heavy....put in a Wilson roof mount. so we will see...
25 JAN 2020I’ve ran hard mounts for years, drilled every vehicle I’ve owned except the current one. Haven’t gotten around to it yet. I’m reminded in the mean time that magnets work. I’ve been very pleased to work some good DX over the past few weeks, including bagging contacts in Uruguay and Cape Verde from my mobile. With few exceptions, if I can hear them I can work them. Would a hard mount be better? I suppose, but in the mean time I’m not complaining.
On that brake light mount - WOW. That price is a tad high!
Thanks for posting the photos of the Third Brake Light Antenna Mount w/ the Laird CB Antenna, and a Stryker 497-HPC installed in my 2019 F-350.
I installed the Predator on No.2 truck for display purpose only, to show the coil is above the roof with the 17" shaft and to show the distance between the cab and antenna shaft. This truck does not leave the garage during the winter.
I have posted a few recent photos in thisnDo you have any pictures of the install?
I have posted photos in this thread and I will post a photo which shows the coil / base of the Laird antenna is not above the roof line but the maximum VSWR is 1.3:1 and transmit and receive up to fifteen miles is great.Do you have any pictures of the install?
