yeah, you're wasting your time. you don't have any image plane for an entire 180 degrees off the back of the jeep. that's the cause of the lower than 50 ohm (29-38) input impedance. neither the tailgate or the frame change that.
So then I shouldn't be able to get my Hi-Q 3-30mhz antenna working there either, right? How do i cut the coax to make it work at that entire range of frequencies?
I'm not disagreeing with you about that. I didn't say it was optimal groundplane, but you have limited choices with a Jeep and with most mid sized vehicles. Don't forget, part of the point is to try and minimize the ground losses that are going to occur in a mobile setup. I disagree with you about it being a waste of time. What you're saying is exactly the opposite of published, accepted, and tested mobile HF installation practice. The vast majority of HF installations for lower frequencies are off of the rear of the vehicles, and a lot of them are on mid-sized vehicles. The only way you get it to work 1/2 way decently is to bond as much as you can.
Read k0bg: "Bonding, sometimes referred to as strapping, is one of the three most important aspects of mobile radio. (...)
The best mobile antenna money can buy, isn't any better than the ground plane it is mounted over. Maximizing the available ground plane is what bonding is all about. On the HF bands, our vehicles act more like a capacitance to ground, rather than a ground plane. The bonding doors and trunk lids has a lessor effect on noise, but does aid in maximizing the ground plane If you doubt this reasoning, here's a little experiment you can try.
Install your antenna first and use an MFJ 259B or similar antenna analyzer to measure the on-resonance input impedance of your antenna. Then follow the suggestions below and once you're done, measure it again. The resonant point will drop slightly and the input impedance will drop perhaps as much as 25 percent. This occurs because bonding lessens the ground losses which are reflected in the input impedance. The better the quality of the antenna, the more noticeable the change will be."
once the source and load impedances have been determined the impedance values as well as their locations along the line are not only predictable and simple to calculate
The average guy that wants to install a CB in his jeep/truck to go off-roading with his buddies is not going take the time to research and learn how to do that. And he shouldn't be expected to, either. Even if he wants to learn how to do that, he might end up at the clown forum and get told how to do it wrong.
