Should the wire that runs from the match ring to vertical base be calulated in the radiater length? It seems like it should be, it is not vertical though
Its at least a foot long and kinda runs horizontal maybe angled down a little to bottom of radiator.
Also while im at it, i only have 3 103" radials now with a 1:3 swr. Will adding the 4th help swr? And should it be longer? What is the formula? My radials are wire and are not perfect, they are tied off to tree braches and prob not all at the same angle. Im working in a tree
