This is my first post here so hi to everyone,
There are a some familiar names here I recognise from other forums I use and no doubt some of you may know me....
anyway,
I have a 1/2 wave silver rod that I removed the matching coil from years ago to use on 20M as a 1/4 wave with radials added, I play around with antenna's quite a lot and decided it would be more usefull to me now as an 11M antenna again, as I want to do something like in THIS THREAD
What I also want to do is to turn this into a 5/8 wave by changing the pole at the base of the antenna for one about 3 feet longer than the origional. I could just add a new coil and play around changing where the tap is, but the problem I have is I can't put ANY antenna's up at home :thumbdown: , so any experementing has to be done away from the house, usually on top of a big hill somewhere. I'm going to be using 16 guage enammeled wire for the coil, so my question is what size coil would you start with, ie. how many turns on what diameter former, and how many turns in would you put the tap onto the coil?
I've also heard about a "magic length" of antenna being 0.64 wavelengths long, a 5/8 wave is 0.625 wavelengths long, so I find it hard to believe that this small difference in size will make much diference at all, but as I am extending the antenna anyway, I could go for either length of element, if one really is superior to the other. I don't operate from home, only portable, so this antenna will be mounted around 18 foot above ground (the size of my portable mast).
I realise that I could go and buy a 5/8 wave antenna pretty cheaply and just add ground planes, but I want to use what I already have, a) because I'm a cheapskate and b) because the more things like this I try the more I learn about antenna's.
I look forward to your replies....
Simon 26OD004
anyway,
Simon 26OD004
