With a typical horizontal dipole, the feedpoint should be pretty nearly directly over the shack area, so the feedline hangs away from the antenna at as close to a 90° angle as possible. That's a necessity, especially when direct-feeding with coax.
If you have a VERTICAL dipole, the feedline still has to get away from the antenna at a 90° angle. At VHF and above, this isn't too hard. At 27 MHz it becomes more of a problem.
You've been given the dimensions (or how to determine them). You don't need any pictures; the dipole is the basic antenna, on which virtually all other resonant antennas are based.
Cut it a little on the long side. Attach center insulator and end insulators. Attach coax to center. Attach non-metallic rope or cord to ends and hoist it up. Determine resonant point and determine how much to shorten. Lower it back down and shorten it equally on both sides. Raise it back up and note the change. Take lots of notes.
Sounds like a lot of work, and it can be. Every installation is a little bit different from every other one, so there's no absolutely perfect length that anyone can predict over the Internet. Experiment! It's the one area of radio where you're free to let your imagination run wild. Try something - see if it works. If it works, improve on it. If it doesn't work, figure out why and fix it.
