Do not put your faith in SWR. An antenna with a low SWR does not mean it is radiating better than another design that might be higher.
I have never had a Fire Stick and I have owned a few since 1990 including a a lot of 5 foot II's and 7 foot origianals that has outperformed any other brand of antenna. Now that said I have used mostly 102" whips, Firsticks, Wilson 5000, K40, Wilson Silver Load, Solarconn Quad Rod and an early 1991-ish open external capacitor design. It was a toss up between the 102" whip and the open air external capacitor type in terms of band width and actual field tests from fixed location to fixed base stations and fixed mobiles. In fact the K40 base loaded antenna outperformed the 7 foot and 5 foot firesticks.
All of the really hard empirical testing I have seen pretty much agree's with my observations with regard to the 102" and the Monkey Made's of the radio world having the best performance under laboratory conditions and real world field testing.
I went from Firesticks to K40 and saw a huge improvement in receive and transmit. Then when I went from a car to a SUV I went to a 102" whip with about 6"-8" inches of aluminum stand off bracket to get the whip away from the vehicle a bit. In each case the improvement was huge it could be seen and heard at both ends. When ever I hear someone complaining that CB does not talk far enough they always have some short fiber glass antenna, a ruber duck window mount, cellular through glass mount or some really gimp magnet mount that looks like a coat hanger with a black wire wound resister mounted to a magnet about the size of a Hockey puck mounted in a poor location. I know it is not a resistor by the way but that is what it reminds me of. It reminds me of a black wire wound resistor!
If you care about what people think of you stay far away from a 102" whip or anything like a Monkey Made or Viper etc....They second you put one of those on your car or a screw driver antenna it will scream "red neck" to anyone not in the community/hobby. When I see a ton of VHF/UHF antenna's on a car my first thought is "cop slow down" than as I get closer I realize it is someone with a N+1 addiction in the 2- way hobby!
