anyone build any ants. for 440mhz and up? outside of a dipole and a 1/4 wave vert. thinking about a quagi, going to try and get it wide banded enough to to cover 440 and gmrs freqs. fm of course.
The fact that you have a low VSWR spot out of the designed bandwidth of the antenna only means that your transmitter will be happy. It is very likely that you will have no gain, or negative gain, in the desired direction. BTDTC2 said:Actually, the VSWR dives below 2 @ ~420 MHz, then squiggles along down to about 1.13, then comes up to about 2.2 @ 450 MHz, but takes another sharp dive down to about 1.5 @ 462 MHz and proceeds back up off the scale.
