Anybody know if you could use this weather-resistant 75 Ohm2200 Mhz RG-6 TV Coax for like maybe a mountain line installation from the antenna to the base?
You could but there are better ways to do it especially if the cable run is several hundred feet. Even RG-6 is quite lossy when you are talking several hundred feet of it.Open wire or ladder line with impedance matching transformers at each end are much better.
The stuff your buddy is talking about getting from the cable company is called "trunk line" and is what they run from pole-pole along the street. It is much larger and has much less lose than drop line. It is generally fairly stiff and has a solid aluminum outer shield and is what would be better suited for what you have in mind.
You might find someone to drive into a pole and knock down however much you need. Works for coconuts!:laugh:
I always wondered if you could use the centers of twin RG59 as parallel line?
