The spring will make the antenna longer, therefore, lowering the SWR. And definitely, make at least 2 notches to have it seat properly.
Bu the way, what cable did you use, RG-8X or
RG-58 ?
RG-58 ?
My tuning tip is almost all the way out. If I turn it in the SWR goes up?? Does anyone think adding a spring would help me get a better SWR?? Figured it might also help the bracket flex less. This is a 5' antenna
I'd like to get lower than 1.3:1 with the RFX on with 15w dk. Does go up slightly with modulation to like 1.5:1. That's on 32. On 19 it's like 1.4:1 and moves up too.
Thoughts.
When I have time I'm going to remove tail light and knock off the paint so I get flat metal to flat metal. Instead of just the 4x #12 SS screws making ground.
You don’t need to remove the paint. Use some star washers. They will grab and make contact without paint removal. I have done both methods on my truck.
