I want to replace my 36 inch tall tram 1180 dual bander with a taller antenna so i can get out further with my Yaesu FT7900R.
I did some research and found a 5/8 wave 2 M is roughly 50.55" tall and a 5/8 on 70 CM is roughly 16.78" tall.
I've looked at several dual band mobiles and the closest one I have found is a CSB-790A which is 62", but I have been advised by my local ham radio shop, they're not sturdy for taking whackings.
This is going on my 4X4 truck which will see some off road use from time to time.
This ham radio shop advised I'd be better off with a sturdier antenna like a Larsen NMO 270 which uses a metal coil as opposed to whatever material is used like on the CSB-790A, and my Tram 1180 which the center looks to be made of a plastic.
Anyways, I'm curious as to if anyone makes a tall antenna that runs on 2 CM/70 CM that's tough as nails? I'm not afraid of a little height.
Thanks in advance.
Thanks in advance.
