The A99 does not have a resistor in the antenna. Like anything that is made by man---some are just not right. But hundreds, maybe thousands have been made and for the most part they are put together pretty well.
The tuning device inside has to do a lot to transform the very high impedance in an end fed 1/2 wave and as small as it is, it does a very good job of taking care of the match.
Tell us what you claim they say they should do, and maybe someone can agree or not to the truth. If you are talking about the gain they show, you are probably right, it is high.
The A99 is not easy to take apart without destroying the antenna. Can you give us an idea how you took it apart and what you saw in addition to the resistor you claim to have replaced?
If you replaced a resistor in the base, it was not an A99 by Solarcon. If you cannot recall or describe the inside, tell me what you found attached directly to the inside part of the male coax connector installed in the very bottom of the antenna where the feedline attaches.
