Would you like to get on the air with a respectable signal but not spend a lot of money on an antenna at first?
...well, I'll probably get assassinated by someone from Sirio, MACO or Solarcon for letting out this 'secret ' - but, here goes...
OK, Many WWDX readers already know about this simple 1/2 wave antenna, but I imagine we get a number of people who simply read & learn but may never sign up or post...
So,
- if you have any type of 3/8" x 24 thread mobile antenna mount which you can adapt for the top of a mast,
and which has an S0-239 coax connector on it,
simply mount it atop your 3, 4 or 5 section mast with any 102"-103" stainless steel or 96"-102" fiberglass whip.
[ Make certain your 102" whip mount has a good insulator! ]
Then, guy the mast safely at each 10' section with non-metallic guy line, like parachute cord,
EXCEPT for the top set of guy lines...
- start them at the top with (three or four) 108" lengths of METAL guy wire attached at the base (bolts?) of your 102" whip mount ("ground").
Then attach the lower ends of those 108" (1/4 wave) metal guy lines to your top set of parachute cord guy lines and pull them down & out, tightly at some basic diagonal angle so the top set of guy lines are metal on top but parachute cord the rest of the way down, and double as the bottom half of your antenna.
...and you've basically made a Starduster, which is simply a center-fed 1/2 wave (vertical) dipole.
Your SWR should end up somewhere around 1.2:1
Now, if you can get this on top of a 4-5 section mast ON your roof, you'll have a serious performer both locally & for DX!
...and NO MATCHING CIRCUIT to burn up or pack up with dirt or snow.
ALSO:
- If you install this on a strong insulated fiberglass rod, so the bracket touches no mast nor metal except for the 108" metal wires & your coax,
then wrap a 5 & 1/2 turn choke in your coax, around a 4" diameter plastic or PVC former and right below the 102" whip hub coax connector...
- you'll have a smokin' clean pattern and probably wouldn't even bother local computer speakers, since there would be near ZERO (common-mode) RF currents coming back down either the mast or coax.
It might be a good idea when doing this to ground your coax before it comes into the house to help bleed off static to ground. A lot of people simply add a barrel connector there and ground it outside the wall.
Stay safe & have fun!
So,
ALSO:
