Hello guys, as some of you guys know I had a forrest fire here a month or so ago and it burnt up alot of the wire I had ran up to the ridge and feed my antenna, well I dont have the wire to fix this....
So, Im looking for something to replace the wire I was using, and Im looking for something to get the job done, or if it works better than what I was using..
The wire I was using, only thing I didnt like about it was, when something heavy stepped on it, the wire always had a bent place the wire, and that was always a problem that had to be fixed....but the stuff I was using has been up there for 3 years...
So, is there anything out there that works as good or better ?.....
What do you guys use for a long run to your antennas ?...thanks..
