I live in a trailer park, and also have one across the road from me, this is why my antenna has been back on the mountain all these years, until last November, when a forrest fire whipped it all out, so now I have my antenna up here at the shack...its against my back porch in the corner of my porch, and its about 12ft away from the power lines, but its not going to fall on its own.....I don't like it been there, but its the only place I have for it right now..
But Im in the process if making plans to move it over on the front side of my trailer.....this will put me 26-28ft away from the lines...I know that's still a little close, but have no plans on letting it fall...
So heres what I have in mind doing....
Heres what I came up with, getting me a 3ft piece of 3" steel pipe, and dig a hole and drop this pipe in the ground and run cement around it, and leave maybe around 6" sticking up..
Then go with a 21ft joint of 2" steel pipe, and drop some inside the 3" pipe and this will allow me to have 18ft above the ground, in which I will use a brace up around 10-11ft on the side of my trl, have a nice steel brace and clamps for this.....
Then get me a 10ft joint of 1" steel pipe, and drop about 3 or 4ft inside the 2" pipe and drill a couple holes through the pipes and bolt them together...and put my Imax and choke on the mast pipe.......not going to use any guy wires, don't plan on been but somewhere around 23-25ft off the ground..
Im looking into setting it up this way, so maybe going to a 4 ele beam....
Not a 100% sure yet tho, just something Im kicking around, see how the neighbors react to this first actually...
May change out the 2" pipe and go to some 1.5" pipe, and then to the 1" pipe...then the Imax and choke....because I know a 3 ele Maco will except a 1.5" mast pipe....will be Galv pipe also...
Yea if I go with the 1.5" pipe, Ill change to a smaller pipe to go in the grd and cement too...
Reason I mentioned using the 2" pipe here was due to maybe going with a 4 ele Maco later, but think a 3 ele would be better in my situation...
But this is what I have in mind doing, mostly concerned how the neighbors are going to react.....
Guess if I went to the 1 1/2" pipe, the 1" would slide inside it, if I go with ID pipe, right ?.......
