Hi,
I just wanted to share my rather unusual homemade CB antenna. It covers 10 MHz to 29 Mhz, but I designed and built it with the CB band in mind. It is a six element curtain array like the shortwave broadcasters use. I could have gone the traditional yagi or quad route, but I wanted to try something different.
The antenna uses six .6 wavelength horizontal driven elements at 27.205 MHz all at the same time. The bottom two elements start at 1/2 wavelength above the ground. The second element pair is located .6 wavelengths above the first pair, and the third element pair is located .6 wavelengths above the middle element pair.
The total antenna array size is 43 feet six inches tall and 43 feet six inches wide. It is fed with three equal length sections of 450 ladder line back to a central tie in point, and then a fourth piece of 450 ohm ladder line goes from there back to a 5 killowatt 4:1 Guanella current HF balun. From the balun I use a three foot jumper back to my antenna tuner. The tuner came with a built in balun, but it was crap so I used the external balun.
I posted a YouTube video so interested parties can see this very unusual CB antenna.
My homemade 6 element curtain array antenna for the CB band
My homemade 6 element curtain array antenna for the CB band - YouTube
This video shows a receive A/B comparison between a half wave horizontal dipole and the six element curtain array;
Receive A/B test between my 1/2 wave dipole and my home made 6 element curtain array
Receive A/B test between my 1/2 wave dipole and my home made 6 element curtain array - YouTube
...and this is an on the air signal report using the six element curtain array during a contact from my location in South Carolina to a station in New Mexico.
30 over signal report in New Mexico with 200 watts output on my 6 element curtain array! - YouTube
I have been using this antenna for a few months now, and of all the antennas I have ever used for DX since I started playing with CB radios in 1975 this antenna is the best!
Night Ranger/South Carolina 116
