10-4, well thats just it, I wouldnt be able to get any height, Im still looking at trying to put a beam in here...Id rather have that than a GP......
Have those stinking power lines out back, and that sux...
Ive been checking things out and if I put a beam out back, the reflector wouldnt be but 3ft away from the power lines when it was turned into the west....
So a beam would need to be somewhere else here at the shack, dont matter where it went, dont think Id get but 21-27ft at the max on height...man this sux...
The last 3 ele beam I had up, I had a 3" piece of pipe in the grd 3ft and put rebar around the pipe, and filled the hole with cement and made sure it didnt go anywhere, and I put seems like 12ft of 2" pipe inside the 3" pipe....and went to a 1.25" pipe and it was 21ft long inside the 2" and dropped 3ft inside it and drilled 2 holes in them and bolted them together....and had the beam on this, and turned it with a pipe wrench....talked good there for years..
If I can put a beam up here Id do the same thing with it, but not as high...
