Ok so i drove a 8foot rod into the soild about 2 feet from my house.The antenna is 25 ft up on the chimney and my plan now is to run the wire to the antron mount screw and down into the single screw connector on the clamp.I bought 6 awg shielded stranded wire 35 feet.I wanted single copper but all they had was stranded and they had unshielded but i seen what happens to exposed copper in these new england elements.Now is it best to clampo the wire to the ground rod directly or use the little 1 screw spot on the clamp?And is this stranded 6awg good enough being shielded and all.I know that in reality it probably wont be protecting me from lightning but it should help my recieve a bit.I plan on adding one of those coax protectors later on.
