I have a Wilson 5K Magnamount and got a new car (2009 Nissan Altima) and thought a trunk lip mount would look a lot better so I got a trunk lip mount (originally from a Wilson 1000) from a friend. I changed out the coax to LMR 400, installed the trunk mount and screwed on my 5K base & whip. when checking the swr's it pins the needle and the receive is quiet. Checked it against MFJ and pinned that as well!. Here's what I did do:
-Checked thoroughly coax, solder joints, connector, & Assembly viasually and with continuity meter. Everything checks out as it should.
-Bonded/Grounded the doors, hood, trunk lid, radio, and the set screw on the antenna mount.
-Tried the trunk lip mount antenna on another car (2007 Acura TSX) with same results
Oddly enough when I throw the magnamount on the trunk the swr's drop to around 1.7 Right now I have the magnamount on the roof and the swr is 1.2. I would really like to have this trunk lip mount work properly because it's such an eyesore having the 5K on the roof. A knowledgable friend of mine suggested that perhaps the rear window defroster might be messing with the antenna but it's just too strange how after trying the antenna on another car it still didnt work.. As I said the Wilson 5K works just fine with the magnamount. I would really appreciate any insight anyone may have.
