ADDING ADDITIONAL COAX
K
KD5VHF
Guest
At HF freq.s the loss from the extra connectors is VERY little. Many different ways/methods/opinions to seal the connection. I use a couple of wraps of electrical tape then cover the wraps with "Plasti-Dip" - (the rubbery stuff you dip tool handles etc.in) Works for me.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)">
<hr />73, Mike </p>
I call it Bandaid Kid tape <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
Yes, most Ham shops, or RadioShack sells it.. Works well, and removes with little effort.
Tar-like substance, keeps the 'weather' out 10-4?
73's, -=BattleAxe=-
</p>
I just relocated my antenna into a taller tree. I need to add an additional 50 feet of coax onto what I already have. I have been told that's it's not a good idea to add coax to an existing coax. I also heard that there was some type of tape that can be used to cover the connectors where the additional cable was added. Can anyone give me some advise on adding cable and if there is a special type of tape that can be used to wrap around connectors?
Any input on this will be appreciated.
</p>
    535A has left the room.
  • @ AmericanEagle575:
