Adding more ground elements to a ground plane
nfsus
Yeah its turned off, touch it
May 9, 2011
467
237
53
47
Arkansas
If you took a ground plane such as a clr2 that has 3 ground radials and strung bare thin copper wire between them spaced out say every 5 inches,making a web what would that do? Would it increase preformance at all?
Reactions: ShadowDelaware
based on how much ground radials are pounded into us i would have assumed that there would be a continuing gain to them. interesting thanks
I guess I never considered the difference between the radials below a ground plane and a ground radial system
I see he talks about a metal roof. Since my ground plane is stuck at the moment pointing at the ground on top of the tower, it has me thinking about things like lower is better. Hahaha.
But seriously I have a peaked metal roof that with a small mast I could hit a wavelength easy enough. I wonder what, if any performance difference I’d see mounted over the metal roof vs 60ft to the bottom of my .64 using its 4 built on ground radials.
