I picked up a very cheap Cushcraft AR10 on ebay.
I would like to know the best way to adjust it for working on 11 meters band.
I have the ATU MFJ904 but wonder if there is another way of adjusting it from the antenna end ?
A half wave length vertical for 11 meter band is 17:3 feet, the cushcraft measures 17:5 feet.
How much power PEP am I likely to loose from an umatched antenna tuned via a tuner?
Should I cut 2 inches from the top of the antenna or is there another method to make adjustments antenna end ?
I am studying for my M3 callsign at the moment so wouldn't want to cut the antenna too much antenna end, rendering it useles for when I finaly get licensed to use 10 meters.
Will the MFJ904 tuner , tune 11 meter band and then allow me to use it on 10 meters when I have passed the associated radio amateur ticket?
I have even managed to tune a G5RV on to the 11 meter band with this ATU and that is miles out length wise?
