well after reading that, pretty much every antenna ive considered is crap including the one I have, and no matter what my settup will suck and damage my equipment! people really spend thousands on their mobile setup? what HF antenna can I get for 1200$?
Yes. My current set up is:
Kenwood TS480SAT, $919
Kenwood TM-D710, $639
Little Tarheel II antenna, $399
Extended antenna whip, cabling, power distribution blocks, fuse holders, Mix31 ferries, roughly $150
I get coverage from 3.5MHz through to 440MHz. I can talk all round the world with 100W depending on what band I'm on and what conditions are like. USA from England on 20m to 10m bands are pretty much a given. There's a guy in New York called Mike Morretti, W2YP, who I contact regularly and a fortnight ago was the very first time in 5 years I've actually spoke to him from home as every other contact I've been in my car. Plenty of mornings I've been driving down the road on the way to or from work and talked to Australia on the 20m band.
I will make this point though. The money isn't what got me the contacts and the performance. I've seen a similar HF set up and more expensive ones which have performed worse. What has got me the contacts and performance is the 2 days I spent installing it with most of that time being spent installing the antenna system (antenna, cabling, choking, bonding etc). I could swap that antenna out for $20 mono band hamsticks and blow away a $700 Scorpion 680 if it was installed poorly.
Throw a magmount on the roof, hook your CB up to the 12v accessory socket and yeah you'll make contacts and probably work a bit of DX. Is it as good as it could be? No. Would you be happy with it? Quite probably given you've not got anything else to compare it to and to all intents and purposes its doing the job. eHam proves this as it is absolutely full of top rated reviews for absolutely crap antennas because the people doing the reviews have never experienced anything else other than crap antennas and it makes contacts and works a bit of DX so must be good. However if you were to go from a proper full installation done as per that site to throwing a magmount on the roof and running a CB from the 12v accessory socket or you'd had a yagi up at home then gone to a compromise antenna then no you wouldn't be happy with it because you know it could be so much better.
You're nearly there spending money wise. Revising your antenna mounting choice and choosing a different antenna is the biggest money you'll need to spend. The rest of it is mostly time and a few bucks for bonding straps which you can make from flattening the braid from RG213, serrated washers and crimp/solder lugs to do a bit of bonding even if you only do the hood and the trunk.
Nothing is better in my opinion than putting the effort in and being rewarded many times by being told you're one of the loudest stations they hear even though you're running maybe 1/10th the power of everyone else, or busting a pile up full of stations with yagis on big towers. When that happens to me I get a mental picture of some poor bugger who is sat there in his shack looking at the $10,000s he's invested, his linear, his antenna farm and going incandescent with rage at being pipped to the DX by a guy driving to work in his car.
