How did you adapt the CT-118 cable to key the AL-811 amp?...
I key my amp on the FTdx3000 with the tuner output connection(same hook-up can be used on Ftdx1200)
Pins 2 & 3 from either plug(Tuner/Linear) should go to the RCA jack marked relay on the rear of the AL-811....
Al-811....switches IP/ Xmit OPR and of course power on....
If hook-up is correct when mic is keyed in SSB, you should hear the relay close in the Al-811...
If relay keys...switch modes to CW...turn the AL-811 Xmit Oper switch to STBY...
Reduce TX power to NO more than 25 watts carrier...
Al-811 switch to Xmit Oper/key transmitter...tune controls as listed in AL-811 manual...Output with amp tuned correctly should show 400-600 watts depending on band...
If all correct...then transmitter power may be increased for SSB to NO than 50 watts PEAK....You should see 400-500 watts on voice peaks PEP...if all is correct, then you are ready...
Word of advice 500 watts PEP on SSB should not be exceeded, this will make the amp run well and last for long time.
Today's 811a tubes are not very forgiving, so keep carrier where I stated and keep tuning time under 10 seconds and rest the tubes 20-30 seconds between each adjustments.
ON SSB keep the GRID current below 100...40-60 is best and she will operate well...
Hope this helps
All the Best
Gary/W9FNB
