If the rest of the group has not informed you enough...
When you "spike" a MOSFET - you have two things to concern with...
Saran Wrap and Surge Arrestor.
Saran Wrap - being even thicker than what is in the devices' package.
But the concept - of using thin material to insulate the Gate from the mess it has to control underneath it you only have so much insulation and if too thick affects the devices maximum useable frequency bandwidth
Surge Arrestor part; is in the Mess that in itself is designed to self destruct and blow a fuse, itself or a whole string of parts connected to it That is built into the device itself.
Ever use Saran Wrap in a Microwave? It'll eventually get too hot and melt onto your food - or worse...
Keep fresh batteries for the Smoke detector handy...
The Surge Arrestor is in the substrate itself - too much current is one thing - too much voltage - you can cause it to "backfire" - the power generated by the circuit - even if it's fed by less than 50% of it's maximum RATING for Reverse Breakdown - the EMF and EMP caused by overdriven Gates and the pulse generated by the mess on the opposite side - will cause the "surge arrestor" the design is, to fail - in a conducting condition - and either blow a fuse - melt a wire, burn a trace - melt lead or see above...
As you search for MOSFET ratings - one thing you do need to pay attention to is the Datasheet...
Too much of a good thing - usually is...
Some power supplies come with "overload protection" but are only as good as the ability to sense such conditions.
The problem with MOSFET's are their inherited "Zener" ACROSS (it's built this way) and how long it can stay "triggered" - a recovery issue - so as you put RF out there - any VSWR issues reflect their condition onto the leads of this device - and if excessive - will begin to clamp and keep clamping until it self destructs.
