This old beater cobra 29 Ltd classic is just a radio I use for experiments that I’ve had around forever. It’s not about fixing it so much as it is learning what I’m doing. I have spend the last 2 mornings practicing how to do alignments, and I figured out a couple tough problems without asking for any help. I was rather proud of myself that I got it receiving hella good now, set the bias voltage that was way off and then got it back on frequency. Unfortunately now I’m at a stand still.
I got to the transmitter alignment part; according to the service manual, it said connect the scope to r61 and set the cores of L17 and L20 at the bottom and adjust L32 and L21 for a max. I assumed this meant to bottom out L17 and L20. I did this (took them all the way down) and noticed when I keyed up I had zero modulation. No surprise there. L23 and L21 never reacted on the scope at all for some odd reason like the manual said, so I moved on and brought L17 and L20 back up BUT played hell trying to get my modulation back. This radio was keying around 2 watts and swinging to around 7 before I got my palms on it, now it barely moves the meter on key up and barely swings at all. I see it moving as little on the scope when I key up but it does not move my external meter hardly at all. And this all happened after I moved those 2 pots according to the service manual.
I have been adjusting these pots relentlessly since. At first the meter was halfway up on dead key and actually swinging backwards. Then doing nothing at all. Moving back and forth between L17 and L20 I finally got my dead key to 1 watt or so and about 2 watts if I’m lucky on swing. At least it is now better than doing nothing at all or swinging backwards like it was.
What did I do to cause this? And equally as important, what do I need to do to get modulation back? Anyone have any ideas on what I did wrong? And its okay to call me dumb, I’m trying to learn and can take it like a man
