In a draft Report and Order (ET Docket No. 15-26) to be considered at its July 13 open meeting, the FCC is proposing to lift a nearly 2-decade-old suspension of Amateur Radio access to 76-77 GHz, giving the Amateur and Amateur-Satellite services access to the full 76-81 GHz band on a secondary basis. The FCC also reduced Amateur Radio’s status from primary to secondary in the 77-77.5 GHz segmen...
Continue reading...
Continue reading...
