Thank youNot sure what your pin configuration is but if it is "standard" (3x3 + 2 coil) then this should work:
https://us.idec.com/idec-us/en/USD/Relays-&-Timers/Relays/RH-Power-Relay/p/RH3V2-UDC12V
Not sure it’s not my Amp it’s a friends. I tried cleaning old and works but not well.Let me know if that works. I have an 811h. What precipitated the failure?
Yes the receive is horrible when using the AmeritronI just ordered three of them from this outfit. The original Ameritron relay will arrive from the factory with the contact points visibly misaligned. Causes uneven wear and intermittent contact. Sometimes in receive, sometimes on transmit. Sometimes on both.
Well, that's we we found the last half-dozen Ameritron amplifiers that came through here. Brand-new replacements from MFJ/Ameritron were the same way.
Sure hope this part's pins line up with the circuit board holes.
