A customer brought in his AL1500 today. It was smoking the 20-ohm 10 Watt start resistor every time you powered it up. Turned out his tube was bad. That resistor had done its job as a fuse, no damage to the rectifiers or filter caps. A good tube and a new 20 ohm resistor put him back on the air. Happened to notice a repair we had done a few years ago. The single-pole "run" relay that looks so damaged in the pic above had gone bad a few years back. We replaced it with a 3-pole version of the same relay, with all three poles wired in parallel. Hadn't thought about that fix in a while. I don't stock the single-pole part, and using the 3-pole version to fix Ameritron will be our standard replacement for now on.
This may be your only hope, a relay with a higher current rating than the original single-pole part.
