Amp question...
T23
645
12
If I am running an amplifier on 10 meters on a sideband only radio do I need to lower my output wattage at all? I wanted to use my JAWS II 150 amp ( puts out 150 watts on high an 80 watts on low ) with an HTX-100 which puts out 25 watts on high and 5 watts on low. I don't think it would be an issue with 5 watts but is the normal 25 watt output to much?
T23
If you can, take the lid off of that amp, take a pic and let us see what is inside. It will help answer some questions about what it is capable of.
