so i got the beat up and broken 32 pill that nate jones from hopper built sent me squared away for the most part, but the relay sticks. transmits fine but when you unkey the relay sticks and the receive is quiet although you can still hear the receive and stations coming thru. turn the amp off and back on will reset the relay. any thoughts on what could cause this? FYI: to save the unnecessary "its my station setup" posts its not. i dont have high vswr, common mode current, rfi in the shack, low voltage, high voltage, wrong coax length,bad antenna etc etc etc. its the amp! all my boxes and equipment run perfect and my mobile is top notch. its the amp that is at fault. it was sent to me in a used box with very little packing in it and it got completely destroyed. see pics for reference. i would hate to throw this one away like the other 32pill i bought from him which he could not get to work properly.
