If you want a small foot print, easy to build, 2-element beam that works GREAT, check out the Moxon!
For CB, the antenna is as follows (using 14ga wire):
The boom length is just under 5'! Yes, 5 feet for 2-elements!
It's only 13' wide, unlike most beams which are approx 18'. SWR across all 40 channels is less than 1.3.
A critical dimension is where the two element tips meet! For this antenna it's a gap of .361'. You can use any dielectric and drill a small hole to loop the wire through. A small piece of 1/4 wood dowel is cheap and easy! Just coat it with COAX-SEAL and black tape to protect the wood.
You can download a the small FREE program to build the Moxon here:
http://www.qsl.net/ac6la/moxgen.html
You can make the frame out of 1X4 in the form of an X. Secure the wire to the wood with a staple gun (not stapler). Once you have the feel for the antenna, you can buy PVC (very flimsy) or fiberglass rods. I have used an old Cubix quad spider and fiberglass to make a stressed moxon. There are all kinds of options for the frame. Even an old reflector off of a Moonraker 4! Just make sure it is NOT conductive!
