Hey Guys, I need help. More so than the obvious. lol
I have a problem called OCD. Everything I do has to be perfect that's why I have yet to get my base up and running.
While on my quest for perfection with my base antenna I did a continuity test on the coax and antenna. I do not like what I have found and I am getting mixed reports as to whether this is normal or not.
When I use my multi meter with the audible continuity function I am getting the 'beep' when I touch the center pin with one probe and the shield with another. I removed the PL259's and the outcome is the same. Not good is what my thinking is. The coax is 9913.
I also get the 'beep' when I check the antenna. One probe inserted where the center pin goes and the other on the threaded part of the S0239. The antenna is an Imax 2000 that is being replaced with an I 10K.
My thinking is that the coax and antenna are done. Can I get some confirmation here one way or the other. This obsession I have for perfection is going to kill me yet.
Side Note.....Radio and amp was up and running fine on a test run with an SWR of 1.4 when running 300 watts. I just have to know about this continuity issue.
